TwinTurbo.NET: Nissan 300ZX forum - Re: 91 tt head mating with 95 na short block
Tech@EPR
on April 27, 2016 at 11:03 PM
posted by Oriznal
on April 27, 2016 at 10:05 PM
you can run either NA or TT heads on any version block (NA or TT) head bolt pattern etc is identical on all variants of the DE platform
Oriznal
22:05:03 04/27/16
Re: 91 tt head mating with 95 na short block -
Tech@EPR
23:03:12 04/27/16
the block/head match is not the problem
shaggee
08:52:45 04/28/16
Re: the block/head match is not the problem
Oriznal
23:17:49 04/28/16
You will have to change over two exhaust studs iirc.
michaell32 (FL)
08:05:40 04/29/16
Re: You will have to change over two exhaust studs iirc.
Oriznal
19:25:13 04/29/16
Heads & lower plenum need to be matched together AND...
06:52:10 04/29/16
